10W Stereo Audio Amplifier
- Rajkumar Sharma
- 28.198 Views
- moderate
- Tested
- SKU: EL34865
- Quote Now
This project is a 10W Stereo Audio Amplifier based on TDA1521 IC.
Description
The project built around Philips TDA1521 IC, The project provides high quality audio 2X10W Audio output. The device is specially designed for mains fed applications, (e.g. Stereo TV Sound and Stereo Radio). The circuit designed for asymmetrical power supply systems.
Specifications
- It has few external components
- Input muted during power on and off
- Low offset voltage between output and ground
- Excellent gain balance between channels
- Short circuit proof IC
- Thermally protected
- Supply 18V DC @ 3.5A
- Output Power 2X10W
- Voltage Gain 30dB
- Frequency response 20Hz-20Khz
- Input impedance 20K Ohm
- Output load 8 Ohm
- Recommended power supply 18V @ 3Amps
Schematic
The TDA1521 is not available at both of the largest electronics parts distributors in north America. Is it obsolete?
It may be obsolete but still can be found on eBay.
Indeed NXP TDA1521 is obsolete with no cross available. Take a look at Mouser Parts: 511-TDA2009A and 863-LA4625-E to see if they will work for the application. Mouser.com
