18F4550 USB Proto Board
915
1
This board is a Microchip PIC prototyping board for the 18F4550 microcontroller using USB. It is designed to have the PIC loaded with a USB bootloader and then a separate programmer is no longer needed. The board has all the circuitry needed for a successful USB interface. Free I/O pins have 1-3 solder pads for easy connection for prototyping. This board is based on the one I use for all my own USB experimentation, and is compatible with the firmware and software in my 18F4550 USB Interface article, my PIC USB Bootloader article, and others. It should also work fine for other PIC USB interfacing projects, such as HID or CDC (virtual COM port) applications.
18F4550 USB Proto Board – [Link]
One Response on “18F4550 USB Proto Board
Leave a Reply
