1Hz to 2MHz Function Generator with XR-2206 IC
2840
electronics-diy.com writes:
This is a 1Hz – 2MHz XR2206 Function Generator kit that produces high quality sine, square and triangle waveforms of high-stability and accuracy. The output waveforms can be both amplitude and frequency modulated. Coarse frequency adjustment is accomplished using 4-DIP switch for the following four frequency ranges; (1) 1Hz-100Hz, (2) 100Hz-20KHz, (3) 20KHz-1MHz, (4) 150KHz-2MHz. Frequency output can be fine tuned using P1 and P2 potentiometers.
1Hz to 2MHz Function Generator with XR-2206 IC – [Link]
Leave a Reply
