41 Perfectly Sphere Water Droplets Aligned to a Grid
267
positioning systems I – falling objects from pe lang on Vimeo.
41 Perfectly Sphere Water Droplets Aligned to a Grid… [via]
achine that adds drops of water onto a special textured surface. Each drop forms into an almost perfect sphere through the surface tension of the water and the omniphopic Material. The electronically controlled pipette wanders through a square grid of 21 x 21 drops to form a micro-matrix and returns to the beginning. After approximately 300 minutes, and when the water drops have evaporated, the same process starts again.
41 Perfectly Sphere Water Droplets Aligned to a Grid – [Link]
Leave a Reply
