TRENDING:
8 Channel LPT relay board
  • Rajkumar Sharma
  • 26.440 Views
  • moderate
  • Tested
  • SKU: EL34953
  • Quote Now
Specifications
Channel Relay Board is a simple and convenient way to interface 8 relays for switching application in your project.
  • Input – 12 VDC @ 336 mA
  • Output – eight SPDT relay
  • Relay specification – 5 A @ 230 VAC
  • Trigger level – 2 ~ 5 VDC
  • Berg pins for connecting power and trigger voltage
  • LED on each channel indicates relay status
  • Power Battery Terminal (PBT) for easy relay output and aux power connection
  • Four mounting holes of 3.2 mm each
  • PCB dimensions 169 mm x 72 mm
Schematic
schematic
Parts List
parts
PCB
RELATED PROJECTS
TOP PCB Companies
