A Low Cost Hearing Aid
1783
1
Application:
Medical grade hearing aids are very expensive, if a person needs help hearing but not necessarily the full cost and capability of a prescribed hearing aid, this might be an option.
Description:
This is a less expensive, and DIY option for a hearing aid.  It is not a substitute for a real hearing aid that an audiologist would prescribe.  Amplification of all sounds and frequencies, or constant use in loud environments can cause additional hearing loss.  This circuit could be helpful for some types of hearing loss and occasional use, as well as fill in during the average amount of time people wait to get a hearing aid (7 years).
The condenser microphone picks up acoustic signals, that then pass through the preamplifier stage composed of Q1, a BC547 transistor and a few resistors and a capacitor.  The output from the BC547 preamplifier is then fed into the input for the amplifier circuit through the variable resistor R1 and C2.  IC1 is the amplifier, a TDA2822M which is designed for low-power portable applications, and in this case, the output is bridged to drive the single earphone.  A small LED is included to indicate power status and hopefully remind you to turn it off when you take it out.
A Low Cost Hearing Aid – [Link]
RELATED POSTS
One Response on “A Low Cost Hearing Aid
  1. I wonder why the volume control is connected backwards? It shorts the signal from the preamp transistor instead of dividing it.
    When this volume control shorts the signal from the preamp then it increases the distortion and it can kiss low frequencies Goodbye.
Leave a Reply
