Altoids Tin Radio
871
Craig writes… [via]
I’ve made a half dozen battery-free crystal radios in about eight weeks. But I always wanted to try to stuff one inside of an Altoid tin for on-the-go. The short ground wire and long antenna wire that connect via an RCA plug, store neatly inside the tin. The 2000 ohm crystal earphone would fit in the tin if the long tube was chopped off. 200 turns of a 27 gauge wire on a 5/8
Leave a Reply
