An AVR-based power usage logger
205
This device monitors household power usage and logs it to an SD card. A simple analog front-end amplifies the signals from voltage and current detectors and an ATmega168 microcontroller computes the power consumption using the formula P=V*I. The voltage and current are each sampled at 9615 Hz so the integration should be fairly accurate even for highly non-sinusoidal loads such as computers or fluorescent bulbs. A graphical LCD shows the power usage as a strip chart and can also act as an oscilloscope to display the voltage and current waveforms. The current is amplified in three stages (1x, 10x, and 100x) so that different gains can be used giving accurate readings for both high and low power usage. [via]
An AVR-based power usage logger – [Link]
Leave a Reply
