Analog meter clock
633
This is a clock using analog meters. This is using PWM (pulse width modulation) mode on the AVR, which in theory is fairly easy. I’ve played with PWM on AVRs before, and an old posting here gave some details of what I learned. It was a bit of work to manage PWM at the assembly language level, but the dev environment for Arduino makes it really easy to use. [via]
Analog meter clock – [Link]
Leave a Reply
