Arduino Simulator
797
Arduino Simulator – [Link]
This Arduino Simulator app gives the user the freedom to work without the basic setup of hardware and software. It is designed to be used by beginners and also, experienced developers, who want to quickly develop Arduino projects.
The developer can make the necessary changes in the code – delay, pin number, and state – 0 (low) 1 (high) – and check it immediately. The app shows the breadboard, complete with 14 LED pins.
You can drag and place the wires in the correct positions to connect to Arduino. If the wires are placed according to the code, then it will show the expected results. Once satisfied, you can save it and email it. The code can be copied and used in an actual project just as easily.
This app is an easy way to work through Arduino projects. With customisable codes, and a simple to use interface, this Arduino Simulator app from Schogini Systems is a convenient app for Arduino developers.
Leave a Reply
