AVR ISP programmer parallel interface
638
This board can be used to program AVR Atmel microcontroller’s from a parallel printer LPT1 using ISP functionality In System Programming. This type of programing is preferred by many people because you don’t need to move the microcontroller to a programing board, you program it directly on the target board. This board is also compatible with PonyProg a well known programing application.
AVR ISP programmer parallel interface – [Link]
Leave a Reply
