Awesome Hexapod Packs an LED Matrix
279
[via]
SAMSA is based on the Wiring board, with an ATmega128 microcontroller, and SAMSA II on the Arduino Mega, with an ATmega1280. Both are pretty similar, tough the ATmega1280 has 8 KB SRAM, twice the ATmega128. For SAMSA II the Arduino IDE was not used. The software was written directly in C++, using some libraries from both Arduino and Wiring.
SAMSA II has also two additional microcontrollers. One is an old Arduino Mini (ATmega168) located in the head, tasked with handling the sensors. The other is an ATmega8 and is integrated in the display. The firmware in the display was replaced with another one, freeing the main microcontroller from handling the display pixel by pixel, storing the frame buffer, etc.
The head’s microcontroller is responsible for sampling, filtering and processing sensor’s data. The data from the Sharp distance sensor and the lateral IR sensors are combined in a single “super smart distance sensor
Leave a Reply
