Home Blog
Reliable soldering with fluxes
 www.scienceprog.com writes:
Reliable soldering can be achieved by soldering clean surfaces. Usually surfaces are cleaned with abrasives and solvents, but after surface is cleaned surface immediately oxides especially when heated. During oxidation surface is covered by thin oxide film which prevents solder from contacting to metal. This is why flux is used in soldering process. In order to remove/deoxidize surface flux must be applied during soldering. Flux chemically removes surface oxide when heated and makes good metal to solder contact.
Reliable soldering with fluxes - [Link]
Search Site | Advertising | Profile | Add your link here | Contact Us | LED Displays | Wholesale iPhone Parts
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronics Discount Codes
  Electronics-lab.com - 2002-2010
Any logo, trademark and project represented here are property of their owner
