civicbynature writes -
Thanks to jersagfast @ TheCustomGeek. He wrote an awesome menu program for adafruits 2.8tft breakout board. It has 5 different menu areas as well as a settings area for backlight brightness and sleep timers which saves the settings to EEPROM so the settings are saved even when there’s no power. Plus many more features. I have added many updates. It is now both UNO and Mega 1280/2560. compatible.
I have also added the ability to read actual Vcc voltages at the core using the Bandgap method For accurate voltage readings and sensor readings. And more. If you’d like to check out the latest code it’s available Here on my site.
Cool 2.8″ TFT Touch project… - [Link]
