youritronics.com writes:
This was actually the first time I ever needed to multiplex analog channels so it was a good opportunity to learn how to use them. My task was to measure the temperature of 32 thermistors (NTC) with a microcontroller and later process that data. Obviously you cant find that much analog input channels on your common microcontroller so you need to multiplex the signals. First I looked for large analog multiplexers with 16 input channels but those are way too expensive. As it turns out its cheaper to use more smaller 8ch multiplexers(example Digikey pricing: 2pcs 16:1 mux from TI is $7.84 while 3pcs of 8:1 mux from TI is $1.53). I was able to get the 74HC4051 at a good price so I started creating the design around it.
74HC4051 Analog Multiplexer - [Link]
