circuitvalley.com writes:
This is 60 MHz frequency meter / counter for measuring frequency from 10 Hz to 60 MHz with 10 Hz resolution.It is a very useful bench test equipment for testing and finding out the frequency of various devices with unknown frequency such as oscillators, radio receivers, transmitters, function generators, crystals, etc. The meter provides very stable readings and has excellent input sensitivity thanks to on board amplifier and TTL converter, so it can even measure weak signals from crystal oscillators. With the addition of prescaller it is possible to measure the frequency of 1GHz and above.
60 Mhz Frequency Meter / counter - [Link]
