Home Blog
7 Jun 2012
PCB terminal blocks series MVS15x-IT from Euroclamp provide an added value in the form of an easy connection of wire leads even in tight conditions. Thanks to a construction slanted in 35°, they fit exactly into conditions, where horizontal, neither vertical terminal blocks aren´t the right solution.
A relatively common situation – a construction of your device doesn´t allow you to use vertical terminal blocks and at horizontal ones you face the problem with components placed too close to a terminal block, thus preventing a proper installation of wire leads.
MVS15x-IT series slanted in 35° is the solution for such and many other cases. Available are versions with 5mm as well as 10mm pin spacing. Types with a 5mm pitch can be found in our standard stock offer. Basic components are 2 and 3-pole terminal blocks MVS152-5-IT and MVS153-5-IT. Also available is the MVS1510-5-IT, representing a price convenient alternative, when you need to create a row with 10 and more poles. Terminal blocks are made from PA (polyamide) UL94-V0 class, nickel-plated copper alloy and the screw is from a galvanized steel. Detailed information will provide you datasheets at respective types.
Neither horizontal, nor vertical – slant terminal blocks are the right ones! - [Link]
