Home Blog
25 Jun 2012
Schurter 5500.0655.1 line filter will enable it to you and provides an universal usage, independent on the type of the of the inlet power socket used in your device.
It is necessary to use an input line filter in almost every device. At its choosing, you have a possibility to use a filter combined with an input line socket , or a standalone, most often designed for PCB mounting.
Thanks to a big amount of various electric devices with a non-linear power consumption, the line voltage sinusoid is far distant from a clean form found in books of mathematics. Despite still more stringent EMI and EMC regulations, it is necessary to use line filters – also thanks to the fact, that modern digital circuits with a very low power consumption are potentially more sensitive for disturbances. A similar situation is at analog circuits, where more sensitive circuits are used (amplifiers, AD and DA converters, …). A usage of a filter brings two benefits – a better protection of a device from disturbances and also prevents a noise leakage from your device to a mains line.
A novelty in our portfolio is the Schurter 5500.0655.1. line filter for PCB mounting. Advantage of the PCB version is, that it doesn´t require a space on your device´s rear panel. With a maximum current of 6A, it is suitable even for relatively powerful devices. In the Schurter 5500.0xxx datasheet can be found detailed graphs about the filter attenuation in a common, as well as differential mode. For highest demands regarding EMC, it is possible to equip the filter with a metal shield.
Afford to your devices an undisturbed operation - [Link]
