Plastic housings Tek-Berry series provide a professional look and a mechanical protection to your applications with well-known Raspberry-Pi microcomputers.
Company Teko launched on the market several versions of housings directly designed for Raspberry-Pi. It is unusual to have a possibility to buy a housing directly designed for a given PCB.
Tek-Berry housings represent such an optimized solution for a concrete type of a product, thus providing an ideal solution with minimal dimensions. Probably the biggest advantage is that all openings are already made. There is no need of laborious drilling or milling. TekBerry housings even contain a light-guide for better visibility of light from indication LEDs.
Tek-Berry housings can be found in our store in a transparent, grey and black version. Upon order, we´re able to provide you other versions too. Detailed information can be found in the Tek-Berry datasheet and the Tek-Berry press release. In case of interest, please contact us at info@soselectronic.com.
Tek-Berry will make a coat for your Rasberry-Pi - [Link]
