26 Aug 2007
This is a simple circuit that helps you check the functionality of crystals. You simply connect the crystal, power the board and if the crystal is good a led is lighting.
Simple Crystal Tester – [Link]
Home
Electronics-Lab.com BlogThe electronic hobbyist news blog
26 Aug 2007
This is a simple circuit that helps you check the functionality of crystals. You simply connect the crystal, power the board and if the crystal is good a led is lighting. Simple Crystal Tester – [Link] |
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories |
