20 Nov 2007
Simple, low cost and easy to build power supply. Ideal for applications that doesn’t require too much power. It can provide power to circuit that uses less than 100mA without any problem. The disadvantage of this circuit is the danger of an electrical shock, so it cannot be used if the circuit is in contact with the user. The voltage supplied by this is determined by the zener diode.
Transformerless Power Supply - [Link]
