This ethernet enabled shield is able to deliver power to connected devices using Power over ethernet technology. It uses the same cable used to transmit data to deliver power to connected sensors and modules. This can be messy to implement but this ethernet shield make things easy. You just plug it in, hook up a single power supply at your router, and you are ready to go! [via]
Ethernet Shield for Arduino with Power-over-Ethernet – [Link]
