Wise time with Arduino: First release of the Wise Clock 3 software: [via]
The routine work of porting the “Wise Clock 2″ code to the new “platform” (namely the new 3216 bicolor display) went well. Most of features worked right off the bat. Some coordinates had to be adjusted in order to center the text (time etc) on the larger display. These adjustments could have been avoided if the original code used calculations starting from X_MAX and Y_MAX. Ideally, just by changing these two values, the code should have worked.
“Wise Clock 3″ – PONG CLOCK! – [Link]
