Building an Adjustable Constant Current Load
1098
1
box2
Paulo Oliveira writes:
An adjustable power load is a piece of test equipment that often comes handy in the development of a certain electronics projects. For example, when you are building a power supply, it will come a time when you need to “simulate” a load to see how well your design performs as the load varies. Adding power resistors to the output can sometimes do in a pinch, but often you will not have the right resistor value handy with the right power rating for the test. This is where an adjustable electronic load comes handy. In this article, I’ll show how you can build one using common components available to the electronics hobbyist.
Building an Adjustable Constant Current Load – [Link]
One Response on “Building an Adjustable Constant Current Load
  1. Hi, i would really like to build one of these myself but am unsure of some of the the components in the schematic and was wondering if there a full bill of materials available for this
    many thanks matt
Leave a Reply
