Charge a USB device anywhere even without a PC
93
As today already many devices have the possibility to be powered or charged via USB port, we also react on this trend by adding a USB mains adapter to our offer. With such an adapter you can power or charge almost any USB device.
Adapter MW3NU10GS is a switched type with a high efficiency and its own power consumption of less than 0.30 Watt, conforming to regulation 278/2009/EC second stage (EuP, ErP), as well as CEC level V.
Nominal output voltage is 5.2V and current loadability current-carrying capacity up to 1000 mA. It is an invaluable helper for supplying or charging of various portable devices, which support this function (for example some mobile phones, GPS navigations, mp3 and mp4 players,…). Advantage of such a device is that because of supplying or charging of a small portable device you don´t have to switch-on a PC or notebook with a substantially higher power consumption. Another advantage is a big versatility and perspectivity of usage even for future devices. To the universal usage contributes also a wide input voltage range from 100 to 240V.
Charge a USB device anywhere even without a PC – [Link]
Leave a Reply
