Component tester
1727
coremelt.net writes:
With this tool you can test various electronic components like diodes, LEDs, all kinds of transistors (PNP, NPN, several types of MOSFETs), capacitors, resistors as well as triacs and thyristors. It will show you several physical characteristics after the test was completed, like forward voltages, (gate) capacity and amplification factor. More over, it will show the polarity of the component and identifies the several pins of a package. A very nice and sophisticated project I host for Markus Frejek. I’ve done an additional layout for the device you can see on the left side. This project has found a lot of fans, including myself. The device is powered by an AVR ATmega 8 MCU.
Component tester – [Link]
Leave a Reply
