Computerless Arduino programming hack
265
Teague Labs has developed a device for programming and altering the code on Arduinos without the need for a computer. This opens new opportunities for in the field programming and testing of Arduino projects. [via]
The Computerless Arduino consists of two major components; an Arduino-compatible microcontroller loaded with a realtime code interpreter, and a stand-alone 5 button LCD display to display port values and manipulate code. The display can be connected to the Arduino via a 4-pin port at any time to peek at In/Out values, view the current code, and make changes as desired.
The experimental code for this device is open source and available on Teague Labs website.
Computerless Arduino programming hack – [Link]
Leave a Reply
