Display data dynamically using SVG format
184
lucadentella.it writes:
I was looking for a way to show in a graphic form data coming from a feed on Pachube: I needed to create a dashboard available via web and without proprietary technologies (Flash…). I found this blogpost by Andrew Hazelden where he describes how you can dynamically change an SVG file. The same trick is used by another opensource data collector software, Nimbits.
Display data dynamically using SVG format – [Link]
Leave a Reply
