DIY 63 Watt Solar Panel
547
This project shows how to build a 63W solar panel using plain materials. It will guide you through everything from building the frame to soldering the solar cells. The frame is build of plywood and solar cells is better to be soldered using a low wattage soldering iron. Finally you add the plexiglass  and your panel is ready. Check construction details on the link below.
DIY 63 Watt Solar Panel – [Link]
Leave a Reply
