DIY Laser Cutter for PCB Stencils
2937
1
Laser-Cutter
You can use this cutter to cut very accurate PCB stencils on your home:
Are you sick and tired of using a tooth pick to apply solder paste? Are you still using through hole components because you don’t want to deal with soldering surface mount devices (SMD)? If so, this post provides you with guidelines for building your very own laser cutter for cutting PCB stencils. With a total cost of approximately $200 (it can be significantly less if you already have parts laying around), this project can pay for itself very quickly. While you can get “low cost
One Response on “DIY Laser Cutter for PCB Stencils
Leave a Reply
