DIY Multi-function power supply unit
1475
Embedded-Lab.com has just posted a new project called “Multi-function power supply”. It is not just a simple power supply but it has built-in Volt-, Current-, and Frequency meters. The beauty of this project is that while you are prototyping your circuit, you can continuously monitor how much current your circuit draws at a specified operating voltage. This way you will know in advance how much power your design will require. The built-in frequency counter can measure frequencies up to 50.0 MHz.
DIY Multi-function power supply unit – [Link]
Leave a Reply
