DIY PIC16F883 breakout board
168
dangerousprototypes.com writes:
Phil made a DIY breakout board for the PIC16F883 microcontroller. The board uses a surface-mount single-layer design, and the parts are nicely spaced.  It’s an easy board to make at home using the DIY toner-transfer method of PCB etching. You can download the source files and other design data from his site.
DIY PIC16F883 breakout board – [Link]
Leave a Reply
