DS1307 Real Time Clock Module
  • Rajkumar Sharma
  • 21.996 Views
  • easy
  • Tested
  • SKU: EL39238
  • Quote Now
C053
This project is a Real Time Clock based on SD1307 RTC
Description
RTC Add-On Board offers an easy way to interface a standard I2C RTC IC type DS1307, into your project.
Specifications
  •  5 VDC supply sourced through the interfacing Box Header connector.
  • Battery backup for the RTC board available on the PCB
  • Four mounting holes of 3.2 mm each
  • PCB dimensions 50 mm x 33 mm
Schematic
SCHEMATIC
Parts List
BOM
PCB
1 Comment
Zack
Possible to connect with Android box circuit? My Android box doesn’t have build-in RTC.
RELATED PROJECTS
TOP PCB Companies
