Eagle UPL: Create Drill Line Array
165
561201_554035094636458_1056871667_n
Author: James Connors
Description: This ULP is quite creative and simple to use. Draw a 0 with wire on the milling layer. Run the ULP, the dialog box selection will provide options to either draw an array of holes or vias. Parameters such as Diameter, signal name amount of holes and distance can be defined.
Eagle UPL: Create Drill Line Array – [Link]
Leave a Reply
