Flickr + Nokia LCD
223
The project described below demonstrates the usage of LCD graphical display with the help of available demo source codes.
The LCD in the first place is a tricky device, first of all you need separate power for the back light because of the higher voltage, so the author used a break-out board from www.sparkfun.com (Nokia 6100 LCD including breakout board), this board has built in a DC/DC converter for boosting the voltage, you only need one 3.3V power source.
Flickr + Nokia LCD – [Link]
Leave a Reply
