Flyback Transformer Drivers
811
uzzors2k.4hv.org writes:
Flyback transformers are found in monitors, TVs or anything with a CRT, and are sometimes known as Line OutPut Transformers, or just LOPT. They are used for generating high voltage for the CRT, which is needed to create an electric field, which in turn accelerates electrons towards the screen, which finally excite phosphors and create the image you see. Flybacks are designed to work best anywhere between 15 to 150 kHz, so some experimentation is required to find the intended operating frequency. TV flybacks are generally designed for upper audio frequencies, which is the cause of the high pitched noise heard from a muted TV.
Flyback Transformer Drivers – [Link]
Leave a Reply
