Home Community
Fusible resistor
Welcome, Guest. Please login or register.
May 19, 2013, 08:38:53 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  Fusible resistor
« previous next »
Pages: [1] Print
Author Topic: Fusible resistor  (Read 862 times)
pradeeba
Newbie
View Profile
« on: May 11, 2007, 04:16:20 AM »
how to select the value of fusible resistor
Logged
esp1
Newbie
Gender: Male
View Profile
« Reply #1 on: May 11, 2007, 06:58:59 AM »
hi,
Your question is like asking what size fuse shall I use??
Its not possible to suggest a 'fusible link' without knowing more of the application.
If possible, post a drawing of the circuit you want to protect.
Logged
esp1
pradeeba
Newbie
View Profile
« Reply #2 on: May 14, 2007, 01:05:20 AM »
sorry I cant post the schematics. can u tel me is there any formula to calculate fusible resistor. end application is battery charger. and can u tel me the relation between the  peak primary current?
Logged
esp1
Newbie
Gender: Male
View Profile
« Reply #3 on: May 14, 2007, 07:55:54 AM »
hi,
I would not normally fit a fusible resistor in a battery charger, a standard, slow blow fuse would be OK.
If its a typical battery charger I would expect a 5 or 10Amp fuse would be OK.
Does the battery charger have a current meter??
I'm not sure what you are comparing with peak primary current?Huh
Logged
esp1
pradeeba
Newbie
View Profile
« Reply #4 on: May 14, 2007, 11:29:26 PM »
output power is 1.25W. we used 10E,1w fusible resistor. it got blowed & diode in the bridge rectifier connected in the neutral path also got blowed.then we used 20E,1W fusible resistor, again same thing happened. can u assist me what to do further? ther e is no current meter. my question was is there any relation b/w primary peak current to choose the value of fusible resistor or fuse. if not how to calculate fuse value.
Logged
esp1
Newbie
Gender: Male
View Profile
« Reply #5 on: May 15, 2007, 02:39:40 AM »
If its blowing the bridge rectifier, the problems not with the fuse link.    I would suspect you have a short on the output of the charger. Have you tested across the output terminals with a ohms meter. [ WITH THE MAINS POWER DISCONNECTED] Huh
Also, does it blow fuses when no battery is connected to the output??
Also, is the charger rated at the same voltage as the battery, example:  12Vcharger, 12Vbattery??
Also, is the input mains selection for the transformer set for you local mains supply voltage???
Logged
esp1
pradeeba
Newbie
View Profile
« Reply #6 on: May 15, 2007, 06:04:38 AM »
hi,
Actually there are 8 boards. 6 are working fine. only 2 boards are giving the problem. fuse blows when no battery is connected to the output. power suuply o/p is 5V & battery for battery 3.6V is needed. Smiley
Logged
esp1
Newbie
Gender: Male
View Profile
« Reply #7 on: May 15, 2007, 08:09:48 AM »
The 2 boards that are blowing fuses, have you done a resistance check on the output pins.
I sounds as though you have short on the boards, especially as they blow with no battery connected.
Do you have a circuit you can post, it will make it easier to suggest a repair.
Are the 3.6 Vbty  for mobile phones?
Logged
esp1
Ante
Electronics God
Gender: Male
Never stop learning!
View Profile
« Reply #8 on: May 21, 2007, 04:12:48 PM »
Are the output connectors switched?
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
