Home Community
prevent live and neutral from changing.please help
Welcome, Guest. Please login or register.
May 24, 2013, 07:41:55 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  prevent live and neutral from changing.please help
« previous next »
Pages: [1] Print
Author Topic: prevent live and neutral from changing.please help  (Read 318 times)
keron
Jr. Member
Gender: Male
stay cool
drkarancool
View Profile Email
« on: May 25, 2007, 12:22:55 AM »
please see this circuit.
 http://www.emanator.demon.co.uk/bigclive/ozone.htm
in the first part of the description about making an ioniser /ozoniser,just above the pic of close-up view showing the emitter and tube, and also the neon output level indicator. you can read like this.
The connections between the sections of voltage multiplier are just thin hookup wire, since the potential between stages is relatively low at a few hundred volts. The output goes via the usual safety resistor/s and also passes through a neon and capacitor based current flow indicator as used on the ioniser page. The final output is on three needles pointing at three short tubes made from brass eyelets soldered to self adhesive copper tape. The tubes are all conected to mains neutral via a few safety resistors.
                                                     suppose i use a two pin plug and i accidently changed from live and neutral,it will be really hazardous.any methods to prevent it?
Logged
Ante
Electronics God
Gender: Male
Never stop learning!
View Profile
« Reply #1 on: May 25, 2007, 03:15:02 PM »
A couple of relays might help.
Logged
keron
Jr. Member
Gender: Male
stay cool
drkarancool
View Profile Email
« Reply #2 on: May 25, 2007, 03:49:57 PM »
Hello Ante,
                        can you please explain a  lil more?if any circuits drawing  availabe for this purpose?please help.
                                     iam panning to build a mains voltage multiplier using Cockcroft-Walton  multiplier.
                                          so in order to have ion flow u need to have ground near the high voltage terminal.please see the link i posted.
                                         what about making a positve and negative voltage  multiplier and using it instead of using a ground and  high negative  voltage.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
