Home Community
PWM using 555 timer
Welcome, Guest. Please login or register.
May 19, 2013, 10:32:22 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  PWM using 555 timer
« previous next »
Pages: 1 [2] 3 Print
Author Topic: PWM using 555 timer  (Read 5010 times)
Ante
Electronics God
Gender: Male
Never stop learning!
View Profile
« Reply #14 on: July 22, 2004, 05:33:45 PM »
Darrin,
I don
Logged
darrins
Jr. Member
Gender: Male
All models are wrong; some models are useful.
View Profile
« Reply #15 on: July 22, 2004, 05:39:49 PM »
Ante,
Cool.  It worked!!! Cool
This will help me greatly.  Cheesy
Modeling and simulation are great time savers (not to mention money).
Thanks again.
Darrin
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #16 on: July 22, 2004, 05:54:25 PM »
Darrin,
Good to know, You are welcome Grin!
Ante Roll Eyes
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #17 on: July 22, 2004, 08:54:22 PM »
Ante and Darrin,
Do your simulation programs know what happens to the 555's comparators when the pin 5 voltage exceeds their common-mode voltage limit? I think that the comparators won't work if pin 5's voltage is higher than 1 or 2 volts below the supply voltage, or lower than 2 or 3 volts above ground. Look at the comparators' darlingtons and current-sources that will run out of operating voltage.
Therefore the PWM range may be only from 30 percent to 80 percent, which isn't much.
If you adjust pin 5's voltage range to where the circuit barely works at each end, then it will probably fail when the moon is full (or temperature change, or supply voltage, or resistor values drift, etc.).
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #18 on: July 23, 2004, 04:30:46 AM »
Audioguru,
Honestly I don
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #19 on: July 23, 2004, 08:10:31 AM »
Ante,
I grow hair on my face most of the time, and especially when I see a circuit with its common-mode input voltage limit exceeded.
Have you seen what happens to a TL07X? Its output suddenly inverts! It makes really bad overdrive distortion.
I relate the moon being full with Murphy's Law, and Murphy wasn't even a vampire.
Logged
darrins
Jr. Member
Gender: Male
View Profile
« Reply #20 on: July 23, 2004, 09:59:38 AM »
Ante and audioguru,
The voltage difference between my heat sensor and reference will be, at most, around 300 mA.  I've read that, as a rule-of-thumb, that the control voltage at pin 5 should be between 45% and 90% of Vcc.  Obviously, I'll have to amplify my signal if I'm going to use a Vcc of say 5V.
Given the limitations that audioguru described (with respect to the 555's PWM capability), will this still be adequate to drive my optoisolated tric driver?
I have another dumb question.  The triac that I bought came with a mica washer.  It is my understanding that the metal part that connects to the heat sink is LIVE  Shocked.  I've read that the mica washer should be installed between the metal part and the heat sink, along with some "thermal grease".  What is this thermal grease and can I use silicon compound instead (or is silicone compound the same thing)?  Looking at the inside of a light dimmer, I noticed that its triac had only a non-metalic washer (no grease).  I've heard that there are silicone rubber washers that can replace the mica/grease.  This seems a lot less messy.  Can these washers be found at most electronics stores?
There is supposed to be a full moon tonight, so maybe I should hold off on building this circuit. Wink
As always, thanks for the help.
Darrin
Logged
darrins
Jr. Member
Gender: Male
View Profile
« Reply #21 on: July 23, 2004, 10:21:13 AM »
Ante and audioguru,
Just found another interesting circuit.  This one is from http://home.cogeco.ca/~rpaisley4/LM555.html#7
This circuit looks like it might be a little easier to predict and the pulse width can be between 5% and 95% of nominal.
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #22 on: July 23, 2004, 02:29:16 PM »
Darrin,
This last circuit and diagram is really interesting, I can
Logged
darrins
Jr. Member
Gender: Male
View Profile
« Reply #23 on: July 23, 2004, 05:50:50 PM »
Thanks Ante and audioguru.  I will try experimenting with a few different designs, including the one Ante simulated.  I think I will also try stuffing a few of my temperature sensors (LM34) in a copper tube and use a summing amplifier to calculate an average temperature.  A lot of the temp control circuits I see use only one sensor.  A body of water can have a large temperature gradient (as can large pieces of metal, etc.).
Well, I better hurry and post this.  We are having a big storm here in Texas and the power keeps going out.  Too bad I already dismantled my UPS. Undecided
Have a nice weekend.   Smiley
Darrin
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #24 on: July 23, 2004, 07:32:59 PM »
Wait a minute, Darrin,
You mentioned, Triac. All along we thought that you were PWM'ing from a DC supply.
A TRIAC works like a latch, since once it is triggered, then it conducts and stays-on until the current through it drops very low (when the mains voltage crosses 0V for resistive loads), when it turns itself off. The TRIAC must be triggered for each 1/2 cycle of the mains. You don't need a PWM circuit, the TRIAC does it. All that you need is a circuit that is syncronized to the mains frequency, and gives a short pulse to the TRIAC's opto with a time delay from when the mains voltage crosses 0V.
With a short time delay, the TRIAC is turned-on early for each 1/2 cycle, and therefore gives nearly full power to the load. With a long time delay, the TRIAC is turned-on late for each 1/2 cycle, almost when the TRIAC will turn itself off anyway, and therefore gives a very low power to the load. The time delay must not exceed the time of 1/2 cycle of the mains frequency.
Recently, 2 other posts discussed "lamp dimmers", with circuits to do this. I would find them for you, but lately this site's navigation is very slow.
Logged
darrins
Jr. Member
Gender: Male
View Profile
« Reply #25 on: July 25, 2004, 01:17:40 PM »
audioguru,
This is how I got confused in the first place.  I want to control the phase angle to the triac so I can controll how much power is delivered to my heater.  The first circuit I built uses a heat sensor, a comparator, and a standard light dimmer switch.  When my temp sensor is below the setpoint, the inverting comparator turns on a mechanical relay to my dimmer switch.  This bang-bang controller has poor characteristics, e.g. overshoot, ocsillations, etc.
I'd like the amount of power to the heater to be proportional to the difference b/n my heat sensor and set point.  This could be done by rotating the dimmer switch knob, but obviously I'd like an automated way of doing this.  This is where I thought the PWM and optoisolator triac driver came into play.  No?
If there is some other way to control the phase angle (other than hand-turning a pot), I'm open to suggestions.
Thanks.
Darrin
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #26 on: July 25, 2004, 03:15:06 PM »
Darrin,
I believe you are right, the PWM is the way to go. However it must be with a very low frequency to suit this application, something like 0.1
Logged
darrins
Jr. Member
Gender: Male
View Profile
« Reply #27 on: July 26, 2004, 05:37:53 PM »
Ante,
Just to clarify, I know I'm not controlling the phase angle of the triac.  I'm simply turning the triac on and off for short periods of time.  More heat needed -- longer "ON" time (and vice versa).
I suppose the low frequency is needed to ensure you get some zero crossing with the AC.
As I recall, the reason PWM was recommended in the first place is that the phase control technique has EMI problems because of large current spikes.  Right?
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
