Home Community
Line driver circuit
November 21, 2009, 11:02:48 AM
News: >> Check out the new Electronics-lab.com Photo Gallery
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| |-+  Circuit/General Requests (Moderator: hotwaterwizard)
| | |-+  Line driver circuit
« previous next »
Pages: [1] Print
Author Topic: Line driver circuit  (Read 396 times)
mark86
Newbie
View Profile
« on: October 26, 2009, 01:07:53 PM »
Hi, apologies if this is a bit basic.. but I'm a bit new to electronics and have to design a circuit which can drive the following signal:
  • up to +50v
  • 25ns rise/fall time
  • 8 ohm approx series resistance
  • 33pF total capacitance
i dont really know where to start! would just two transistors do the job? I was worried about the speed and wasnt sure if a more advanced circuit would be required..
Any help or advice would be really appreciated!
Thanks!
Mark
Logged
Hero999
Electronics God
View Profile
« Reply #1 on: October 26, 2009, 03:22:39 PM »
I disagree with you on this being basic, a 25ns rise time at 50V into an 8Ω 33pF load isn't going to be easy.
I would suggest MOSFETs.
What's it for?
Logged
I also post at:
http://www.silicontronics.com
mark86
Newbie
View Profile
« Reply #2 on: October 26, 2009, 05:56:19 PM »
Ok.. well i dont know if thats good or not! at least i dont feel stupid anymore.. if a little worried!
It's a CCD driver signal, the high voltage is required on one signal to multiply the signal before measuring.
So would you use the MOSFETs just as a pair? no special extra requirements?
Thanks!
Mark
Logged
hotwaterwizard
Electronics God
Gender: Male
Service Tech
hotwaterwizard hotwaterwizard hotwaterwizard
View Profile WWW Email
« Reply #3 on: October 27, 2009, 02:53:50 PM »
almost sounds like you could use an audio amplifier ic
Logged
Hero999
Electronics God
View Profile
« Reply #4 on: October 27, 2009, 04:02:02 PM »
How many audio amplifiers are capable of giving a rise time of 25ns?
The circuit isn't too much of a problem, it's the PCB and the components that are the hard part.
Logged
I also post at:
hotwaterwizard
Electronics God
Gender: Male
Service Tech
« Reply #5 on: October 28, 2009, 03:24:07 PM »
Ummmmm slew rate?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #6 on: October 28, 2009, 04:05:13 PM »
The slew rate of 8V/us for the audio amplifier IC is much slower than 50V/25ns for the video amplifier circuit. It is 6250 times too slow.
Logged
Hero999
Electronics God
View Profile
« Reply #7 on: October 28, 2009, 08:05:35 PM »
How many video amplifiers can switch voltage up to 50V into an 8Ω load?
Logged
I also post at:
mark86
Newbie
View Profile
« Reply #8 on: October 29, 2009, 10:18:42 AM »
Somebody suggested a BJT pair, with a diode to/from the rails to provide a bias at each collector. The a dc blocking capacitor, so that the edge on the driver signal would cause a spike that could turn on the transistors. I dont know if this could run fast enough.. and am not sure how to select the components for such a design.
I had not even thought of video amplifiers.. are they often used at this sort of voltage? Or fast enough?
Thanks for the help guys!
Mark
Logged
Hero999
Electronics God
View Profile
« Reply #9 on: October 29, 2009, 01:34:14 PM »
Is there any DC in the signal?
I would suggest using MOSFETs for speed.
If the signal is AC then it does make things easier as a small pulse transformer could be used to drive the high side.
Logged
I also post at:
mark86
Newbie
View Profile
« Reply #10 on: October 30, 2009, 09:47:22 AM »
The driving signal would be from an FPGA, so between +5 and 0 v. Which is why I considered using a dc blocking capacitor to drive the circuit with edges. Pardon my ignorance, but what is the benefit of FETs over BJTs? Are they simply faster?
Thanks,
Mark
Logged
Hero999
Electronics God
View Profile
« Reply #11 on: October 30, 2009, 12:17:26 PM »
Yes, MOSFETS are faster than BJTs.
Logged
I also post at:
mark86
Newbie
View Profile
« Reply #12 on: October 30, 2009, 12:28:19 PM »
Ok. Thanks for all your help. I will look into it!
Logged
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
- [Privacy Policy]
