Traditionally most low to medium power high frequency power supplies (<1kW) are not resonant and use PWM to adjust the amount of power i.e. regulate the output current or voltage.
More modern and higher powered SMPes, typically are resonant. The employ a technique known is zero voltage switching where the transistors are only turned on when the voltage across them is zero. Here's a link with more information.
http://www.powerdesignindia.co.in/STATIC/PDF/200901/PDIOL_2009JAN21_PMNG_TA_01.pdf?SOURCES=DOWNLOAD
