Home Community
need help creating a simple circuit.
Welcome, Guest. Please login or register.
May 24, 2013, 02:58:45 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronics chit chat (Moderators: redwire, wise old man)
| | |-+  need help creating a simple circuit.
« previous next »
Pages: [1] Print
Author Topic: need help creating a simple circuit.  (Read 1193 times)
gamernixin
Newbie
View Profile
« on: December 10, 2009, 02:27:15 AM »
Hi everyone, i'm pretty new to electronics and i have a question.
Well first of all, i made a simple light circuit with 10v bulbs. and as i don't have any resistors i took my old phone charger wich outputs 4,9v. Connecting it to the outlet, i figured that the lights don't get enough power.
but if i were to remove the charger and make a normal plug for it, i suppose all the bulbs would be burnt, as the outlet gives 230v.
so what can i do to make this work?
- Thanks in advance.
-- sorry if my english isn't easy understanding. I'm a dane Roll Eyes
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: December 10, 2009, 04:59:13 AM »
Yes, you're right, the charger doesn't have a high enough voltage and mains voltage is too high so the bulbs will be destroyed.
How many bulbs are there?
What's their Wattage or current rating?
You need a transformer, 9V will probably do.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
gamernixin
Newbie
View Profile
« Reply #2 on: December 10, 2009, 08:32:43 AM »
I got 5 bulbs, and the bulbs are like this:
E-10 \ 10V \ 50 mA \ 0.5 W
Would it matter how i connect the wires whether its serial or parallel?
Logged
Alex Tsekenis
Sr. Member
Gender: Male
View Profile
« Reply #3 on: December 10, 2009, 10:06:00 AM »
Find a cheap 9V, 10VA or so transformer (maybe one of those that you can choose the output voltage), connect all the bulbs in parallel and then to the transformer. Merry Christmas!  Cool
Alex
Logged
Regards,
Alex
Disclaimer: All content of my posts is intended for educational use only. Although the information is given in good faith, if you or any third party attempts to implement any content from my posts or posts related to mine in any way, you agree that you do so by accepting full responsibility for your actions. I will not be held liable in any way for any consequences or damage, direct or indirect, caused by your actions.
Hero999
Global Moderator
Electronics God
View Profile
« Reply #4 on: December 10, 2009, 11:46:30 AM »
Parallel is best because it means that if one lamp fails, the rest will continue working and you can safely mix bulbs with different power ratings.
Of course you could use a 50V transformer and connect them all in series but you're better off with a 9V/10V transformer and connecting them in parallel.
Logged
I also post at:
gamernixin
Newbie
View Profile
« Reply #5 on: December 11, 2009, 07:49:42 AM »
So in serial connections you add all the bulbs voltage, and use that as a pinpoint for power and in parallel you only need the individual bulbs power.
Thanks alot, you have really helped me out Smiley
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #6 on: December 11, 2009, 08:14:04 AM »
Not far off, you forgot to say that the power supply needs to be able to provide enough current to the bulbs.
In your case, it needs to be able to supply at lease 250mA, note: it can supply more than that; it doesn't matter if the supply is 9V rated to 300mA.
Logged
I also post at:
eduard0476
Newbie
View Profile Email
« Reply #7 on: January 19, 2010, 08:01:27 AM »
That simple Bro just make it power supply.. buy the the transformer multivolt make your converter power supply to light your 10v bulb and to solve your problem...
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
