Home Community
Convert 0-30V 3A PSU to 5A or more
Welcome, Guest. Please login or register.
May 18, 2013, 09:16:48 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  Convert 0-30V 3A PSU to 5A or more
« previous next »
Pages: 1 ... 24 25 [26] 27 Print
Author Topic: Convert 0-30V 3A PSU to 5A or more  (Read 180199 times)
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #350 on: November 16, 2006, 01:15:40 PM »
If i use maxim's 2.5V shunt voltage reference instead of D8 then 5V should be obtained on the outout of U1 which doesn't require any voltage divider.What do u think..Huh Huh
I thought about using a 78L05 to replace the zener diode and the opamp, then also power the digital pots from it. You could add a trimpot in the gain-determining parts for calibration.
Quote
Is there any need of finer adjustment pot(1K) if digital pot is used..Huh Huh
Maybe there are enough steps and the resolution is good enough for you. You won't be able to smoothly sweep the voltage up or down. As I mentioned above, a trimpot is needed for calibration.
Quote
Also i want to display the max output
Logged
TooExpensive
Newbie
Gender: Male
View Profile
« Reply #351 on: November 21, 2006, 07:58:34 AM »
as promised I want to post the fruit(s) of my efforts. Thanks again to everybody in the front lines for developing the circuit to this state.
The image quality is very low but its the best I can offer, therefore I have not tried to make an image of the scope line when testing the circuit.
Please keep in mind that its an experimental arrangement for testing purposes.
While building the board I noticed that the board layout is in some places a little unsuitable for this circuit, its very tight and the main conductor pathes are a bit small, but nothing serious. There is always a soltion.
The main facts: The values are always checked by oscilloscope/AC/0,1V-div/2ms-div to get no measurable disortion at the output clamps while driving my selfmade restistor network (pic.5)
Smoothened by 22000uF extern plus 4700uF on board.
Transformer ratings: 630VA 2x29,4V running free (original 1x26,3V off two paralleled windings to which I added 3 turns each)
The smaller transformer on pic.4 is 250VA 1x24V for the first tests but I want to have two outputs.
I exchanged the opamps to LM741 which runs at its supply voltage limits but nothing gets warmer than it shoulds an everything is stable.
What do I get for my money: max Volt out without load: 32,4V
Shortened output current at max. Volts and max. current: 8,3A
Maximum stable output Voltage with 4,3 Ohms attached while turning the Volt. Pot. up and the Curr. Pot. set to max. 27,6V pure flatness on the scope line at given settings while current rises to 6,2A.
Voltage set to 30V without load and turning up the current under load gives 6,25A and the clamp voltage drops to 27,8V again flatline on the scope.
R7 is two paralleled 0,47Ohms/5W but will be exchanges against 0,22Ohms/20W, they get very hot.
Of course bigger heatsink for the output transistors are needed, but its just the testsetup.
Alltogether I hope you will agree to the rating 25V/6A which was my target. It could deliver more by lifting the transformer voltage and using better rated opamps, maybe worth a thought.
Bye for now, and dont fry much power resistors.
PS: on the first test R16 smoked a bit because I exchanged Base with Emitter on one 2N3055 but nothing happened to the rest of the circuit. Man, I hate mounting TO-3 in the late evening hours Smiley .
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #352 on: November 21, 2006, 09:21:07 AM »
Hi Too Expensive,
You probably can't measure it because the waveform will be distorted but what do you think is the modified transformer's voltage rating when your project has a 5ADC load?
How many milli-volts DC does the output voltsge drop from no load to 5A load at 25VDC?
Logged
TooExpensive
Newbie
Gender: Male
View Profile
« Reply #353 on: November 21, 2006, 01:49:23 PM »
I can measure the output disortion, what I did was after my mind to determin the point when the circuit becomes instable or the supply voltage drops too much. When I set the potentiometers beyond this point when driving low resistance loads it shows in form of fast growing spikes on the screen which also shows in dc setting. Of course I cant get this resolution in dc. I cant say how much the output voltage drops at 25V/5A because i didnt measure it yet, but I can say for 30V preset at 4,3Ohms. I measured 6,25A and the clamp voltage dropped to 27,8V. I try to keep that in mind to measure it. Sure it is an important stability point.
Can you repeat the question about the transformer please in other words, my english is not good enough to give you the right answer.
Bye for now.
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #354 on: November 21, 2006, 02:13:04 PM »
Your temporary wires are too long and have too much resistance to properly measure the regulation of your circuit. A wire with only 0.002 ohms will create a voltage drop of 10mV at 5A.
I think your "spikes" are ripple since the U2 opamp is saturated up at the positive supply.
Transformer voltage ratings are at full rated current. We don't know the voltage rating of your transformer because you modified it.
Logged
TooExpensive
Newbie
Gender: Male
View Profile
« Reply #355 on: November 21, 2006, 06:00:42 PM »
Hi again,
now I understand the question about the transformer:
Without mod.: free: 26,33V
loaded circuit with 25V preset/4,3Ohm: 25,7V
modded: free: 28,96V
loaded: 28,3V
I got these values from my records and I could also read the Voltage after the rectifier/smoothing sinks on the big transformer from 37,8V to 34,4V. Should I think about shottky rectifier? Or will thicker wires do the trick...Ill see.
In the original thread the BD249 for output transistor is mentioned...is this usable...are modifications needed to do this?
Bye again.
Logged
MAXPAYNE
Full Member
Gender: Male
It's a little funny!!!
View Profile
« Reply #356 on: November 29, 2006, 01:57:52 PM »
Is there any advantage using  darlington power transistor like DTS4075A(30Amp) instead of 2N3055 ?
Logged
So, What's the craziest project u have done lately ?
audioguru
Electronics God
Gender: Male
View Profile
« Reply #357 on: November 29, 2006, 02:15:14 PM »
Hi Roomi,
Datasheetarchive.com doesn't list the darlington. It would overheat by itself so at least two are needed. The driver transistor and a couple of resistors might not be needed.
Logged
mvs sarma
Sr. Member
Gender: Male
View Profile Email
« Reply #358 on: November 29, 2006, 04:29:40 PM »
Your temporary wires are too long and have too much resistance to properly measure the regulation of your circuit. A wire with only 0.002 ohms will create a voltage drop of 10mV at 5A...............
Hi audioguru
you may recollect the type of power supplies that had two more wires(4 wire method) and the lead drop was taken care of and the voltage is corrected at the load-- i don't mean that we can then use thin wires and take the reisk of fire due to I^2*R loss . in specific case where voltage drop is to be minimised, in addition to proper guage wirs, this remote votage monitoring and correction maybe adopte for this supply also.
regards
Sarma
Logged
When others do our work, it appears  easy!!!
audioguru
Electronics God
Gender: Male
View Profile
« Reply #359 on: November 29, 2006, 04:54:22 PM »
Hi Sarma,
I have seen too many circuits posted that are built on a breadboard with thin long wires all over the place. Some are clipped together with intermittent alligator clips. They cannot work properly.
Logged
mvs sarma
Sr. Member
Gender: Male
View Profile Email
« Reply #360 on: November 30, 2006, 07:45:46 AM »
Hi Audioguru
i agree with you completely-- power projects , for that purpose any project soud be built with proper discipline-- i was only teeling about lead loss compensation from the power supply to the load point--( say 50 to 100 cm for each lead). this itself drops the voltage and the resultant voltage at the actual load would be ( expected - lead drop). this could be compensated by a 4 wire system. that all.
regards
sarma
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #361 on: November 30, 2006, 09:20:45 AM »
Hi Sarma,
I know about remote voltage sensing at the load so that the feedback causes a power supply to produce an accurate voltage at the load without the voltage drop of the connecting wires.
This project is smart because it has the current sensing resistor R7 outside the voltage sensing circuit. However, some people ruin the excellent voltage regulation of this and other power supply projects by connecting a current meter with its internal resistance in series with the load. I think that current should be measured by the voltage drop across R7 in this project, then there will not be a voltage drop.
Logged
mvs sarma
Sr. Member
Gender: Male
View Profile Email
« Reply #362 on: December 01, 2006, 03:15:56 PM »
Hi Audioguru,
Current sensing outside cct Voltage sense-- yes. I shall come back  after a little study
Fine sir
regards
Sarma
Logged
boco
Newbie
View Profile
« Reply #363 on: March 27, 2007, 02:51:14 PM »
Hi guys. I am new on this forum. First of all I am sory for bad english but I hope you can understand mee. I read this posts about power suply modification to 5A. It is too much to read.I read 20 pages but after all I dont hav answer what should I change to get 5A. I know that you will said .....read. I am very busy (family, busines ....) and will be very greatfull if somebody write for me vhich part I must change.
Thank you for your answers.
Best regards
Boco
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
