Home Community
Adding led brake lights
Welcome, Guest. Please login or register.
May 23, 2013, 07:45:57 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  Adding led brake lights
« previous next »
Pages: [1] 2 Print
Author Topic: Adding led brake lights  (Read 2444 times)
tourist
Newbie
View Profile
« on: May 15, 2010, 11:18:50 PM »
I need to build a circuit to detect when the brake lights are on and the turn signals on.  The brake light and tail light are the same bulb.  The tail light uses 2.4 volts then when the brake is applied the voltage increases to 13.8 volts.  This circuit seems to work on my test board.  When the input is 2.4vdc the leds are on at about half the brightness and when the brake would be applied and the input is 13.8 volts the leds are on full.  The input only has two values: 2.4vdc and 13.8vdc.  These components are just what I had lying around and I think I would use a different op amp in the final circuit because I will need to monitor 4 different lights, (2 brake and 2 turn signals)  The turn signal circuit differs by reversing the 10k and the 100k resistors.  The turn signals input is either 0v or 13.8 vdc.
I read out here that the 741 isn't good to use in automotive applications, idk.  I'm open to better components or design but I can't draw too much current from the light circuit because it is monitored in some fashion by the onboard computer.  Any help would be appreciated Thanks.
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #1 on: May 16, 2010, 08:10:05 AM »
Your LEDs are upside-down.
The 741 opamp's inputs do not work if they are less than about 3V and you have one input at only 1.25V.
Here in Canada it is illegal to change lighting on vehicles because too many kids used extremely dim and narrow-angle LEDs that cannot be seen at night.
Logged
tourist
Newbie
View Profile
« Reply #2 on: May 16, 2010, 09:52:27 AM »
The longer leg of these leds (not the one that are actually going to be used) I connected to ground.  I assume that the leg is the anode.  That is the way the circuit is wired and sort of working.  I figure if the led didn't light I would just reverse the lead wires.
The 741 op amp's inputs do not work if they are less than about 3V and you have one input at only 1.25V.
I have seen other posts where you have stated that also.  while the circuit appears to work, with no input on pin 3 (+) the leds are light dimly which may be wrong but with the actual "running" input of 2.4v the output of op amp was about 5v and the leds are on at about half brightness.
I don't know if its considered changing the lights.  I am not removing or modifying the factory lights.  I'm adding a set of supplemental lights to my saddle bags.
So, is there a better op amp to use?  I thought since there were four different inputs, left turn, right turn, left brake light and right brake light I could use a quad op amp package in the circuit instead of the 741 but I'm still just seeing if it can work.  If there is a better suggestion I can try it but these are simply the components that I have at my disposal to test with.  So if the design is ok than I can move on but I don't think that I'm there.
A goal is to have this fit on a 1.5" by 2" circuit board and there is not alot of room where the circuit will be mounted.
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #3 on: May 16, 2010, 10:45:52 AM »
An LM324 quad opamp has inputs that work as low as 0V and has plenty of output current to drive transistors. An LM358 is a dual opamp with the same opmps.
Logged
tourist
Newbie
View Profile
« Reply #4 on: May 16, 2010, 11:51:12 AM »
Well, I thought about that.  Got a CA324E that I tried but didn't get any output.  So I went out and bought the lm324 just in case my ic was bad.  The new 324 didn't work either.  This is the circuit, for the most part.
Now I only hooked up one op amp from the package and left the other pins open.  Will that make a difference?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #5 on: May 16, 2010, 02:03:06 PM »
Again, you drew your LEDs upside-down. The cathode (the line) is supposed to connect to the resistor to ground. The anode is supposed to connect to the transistor.
Your "VCC/2b" has its resistors backwards.
Unused opamps should be properly disabled so they don't oscillate and cause problems but maybe your backwards parts are the cause of your problems.
Logged
tourist
Newbie
View Profile
« Reply #6 on: May 16, 2010, 07:21:12 PM »
I think its getting there.  I'll fix the leds symbols in the next circuit diagram.
Are the 1k resistors on the base needed or should they be a different value?
Are the 1k resistors on pins 3,5,10 and 12 needed  or of a different value?
I drew them in there because I saw them in similar circuits.
I reversed the vcc/2a and /2b resistors because on the turn signal portion I didn't want output until a higher voltage.  Would higher value resistors be better?
Should I or do I need to add some pull down resistors to pins 3,5?
Since these are extra lights on the side bags.  When I remove the bags the leds will no longer be in the circuit.  Do I need to add anything to the circuit for when the leds are removed?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #7 on: May 16, 2010, 09:25:45 PM »
The transistors in your circuit are emitter-followers with a very low base current so the 1k resistors can be replaced with wires.
Quote
They can be up to 33k ohms but each pin needs an additional resistor to ground as an attenuator so that the input voltage never goes higher than the supply voltage minus 1.5V.
Quote
You don't need opamps nor transistors for the turn signals. When the turn signal voltage is 13.8V then it can turn on the LED for that side.
Quote
You don't need 4 opamps since only two opamps from an LM358 dual opamp are needed for the brake LEDs.
Quote
A weatherproof jack.
Logged
tourist
Newbie
View Profile
« Reply #8 on: May 17, 2010, 10:09:30 PM »
Got rid of the Vcc/2b.
Changed Vcc/2a resistors.
I put the pull down resistors on pins 3 and 5 for the turn signal side.  I think I still need to use an op amp and transistor because of the total current draw from LEDs (7-10).  Correct me if I'm wrong, I may not have mentioned the quantity of LEDs.
The brake side I didn't add the pull down resistors because the input will either 2.4vdc or 13.8vdc.  Didn't think they were needed because there is voltage there in the operating state.
I still need to choose the LEDs that I'm going to use so I don't know if the current limit resistors are the correct size.
Am I missing something or does it look adequate?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #9 on: May 18, 2010, 09:08:32 AM »
Red LEDs are 1.7V to 2.0V each. Then 5 can be connected in series for 8.5V to 10.0V. A current-limiting resistor for the turn signals will be (13.8V - 8.5V)/25mA= 221 ohms which is not a standard value. Use 220 ohms/0.25W. This is one string of 5 LEDs that draws only 25mA. If you want 7 LEDs then make one string with 4 and another string with 3 and re-calculate the current-limiting resistors.
The brake lights are dimmed by the opamp for the tail lights. Since you are dimming them by reducing the voltage then LEDs in series cannot be used.
But I don't understand why the opamps are used for the turn signals since the flasher can easily drive only 50mA more for the LEDs without any circuitry except current-limiting resistors.
Logged
tourist
Newbie
View Profile
« Reply #10 on: May 18, 2010, 10:54:54 AM »
This is going on a BMW motorcycle.  I could be wrong but it is my understanding that the "computer" controls these lights and monitors over current and under current conditions.  I have seen an extra 20 milliamps drawn when somebody used a relay in the circuit for their lights.  Don't know if it caused any problems after that first day.  I just know if I took my voltmeter and monitor the lights it doesn't upset the system.  I thought it would be safer to use the op amp and transistor.  I am not 100% sure what would happen if I try to draw that much current from the turn signal side.  I am not sure if anybody knows the truth so I just tried to keep consistent with the circuit.
I have built an array of infrared leds that had 5 in series with a resistor but it seemed to have a cascading effect of taking out the other strings of led.  Maybe my poor design so I again I opted for consistency.  Is it a better design, more efficient to string multiple leds?  I salvaged a sign with a bunch of leds that lit up at the same time and each one had its own resistor so I copied.
I'm still not set on the amount of leds.  I see some units that have 50 LEDs in just one disc.  The next step is to test this with the lens cover I made to make sure it is bright enough for me.
Logged
tourist
Newbie
View Profile
« Reply #11 on: May 18, 2010, 11:47:39 AM »
I'm thinking it may be bright enough.  Hard to actually tell from picture but it does look good so far.
The leds are from that display.  I think they are 3mm high flux. (http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2Fhf3-y5570.htm)  It has a 12vdc and 330 ohm resistors.  While they are not orange, they are close in color to the orange on the bike.  I have similar red leds (not the one I'm testing with in the picture).
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #12 on: May 18, 2010, 02:37:01 PM »
I don't know the spec's for your LEDs. If they are 2.0V and the supply is 13.8V then the output high of the lm324 opamp will be 12.4V and the output of the transistor will be 11.6V. Then the 330 ohm current-limiting resistor limits the current to 29mA and dissipates 0.28W so it should be rated at 1/2W. You could probably connect 4 LEDs in series then re-calculate a new resistor.
LEDs in series all have exactly the same current and the LEDs use the power much more efficiently making light than wasting most of the power heating many resistors.
Logged
tourist
Newbie
View Profile
« Reply #13 on: May 19, 2010, 07:58:53 PM »
Here is what I built and tested and included some real voltages and currents.  I'm thinking this is the final version and going to start on the circuit board design.
audioguru,  Thanks for your help, I hope I interpreted correctly.
Logged
Pages: [1] 2 Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
