Home Community
LM338 Power Suply Current Regulator
May 21, 2013, 08:34:13 PM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| |-+  Datasheet/Parts requests (Moderators: hotwaterwizard, Herman the German)
| | |-+  LM338 Power Suply Current Regulator
« previous next »
Pages: [1] 2 3 ... 6 Print
Author Topic: LM338 Power Suply Current Regulator  (Read 10290 times)
Fight
Newbie
View Profile Email
« on: May 26, 2010, 12:44:14 PM »
In lm338 data sheet asking
Features:
Guaranteed 7A peak output current
Guaranteed 5A output current
But problem is that in Electrical Characteristics:
Vin-Vout = 30V Than max current 1A
what is meaning that
lets Vin = 38V  and Vout = 8V
38-8 = 30
and Vin-Vout = 10V or less than 5A can handle
mean
38-28 = 10
mean 8 to 28V 1A handle
and 28 to above 5A handle
Attatch Diagram
2.    in Application Hints diagram all diagram is designed that can handle 5A
Attatch Diagram
Logged
hotwaterwizard
Electronics God
Gender: Male
Service Tech
hotwaterwizard hotwaterwizard hotwaterwizard
View Profile WWW Email
« Reply #1 on: May 27, 2010, 11:15:18 PM »
Exactly what are you wanting to do here?
You Must Heatsink the components for 5 amps each if not they will only handle 1 amp each.
There is another way to make a high current power supply.
Logged
John DeRosa (Hotwaterwizard)
When in Doubt, Try it out!!
hotwaterwizard
Electronics God
Gender: Male
Service Tech
« Reply #2 on: May 27, 2010, 11:36:51 PM »
http://www.national.com/ds/LM/LM138.pdf
http://www.national.com/mpf/LM/LM338.html#Overview
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: May 28, 2010, 04:02:26 AM »
That circuit will have very poor regulation because the base-emitter saturation voltage of the 2N3055 will vary depending on the current drawn and the 0.47R resistors will have a significant voltage accross them.
Suppose the current draw is 0A and you set the voltage to 12V.
Then you increase the current to 5A.
@0A the VBE of the transistors will be near 0.6V.
Each transistor will have 5/6 = 833mA through it, the same for the emitter resistor.
The voltage will drop by the 0.47R resistor will be 5/6
Logged
I also post at:
http://www.silicontronics.com
Fight
Newbie
View Profile Email
« Reply #4 on: May 28, 2010, 05:50:14 AM »
Quote
The LM338 will only be able to output 5A if the difference between the input and output voltage is under 10V and a good heat sink is used (1
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #5 on: May 28, 2010, 08:02:56 AM »
Quote
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #6 on: May 28, 2010, 12:11:12 PM »
Very Very Thanks Hero
Logged
Fight
Newbie
View Profile Email
« Reply #7 on: May 28, 2010, 12:16:47 PM »
Thats good answer
Logged
Fight
Newbie
View Profile Email
« Reply #8 on: June 05, 2010, 12:20:06 PM »
Attatch diagram
what is the role of emittr resistance 0.1 ohm
why using this resistor
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #9 on: June 05, 2010, 05:11:19 PM »
They help to ensure the current is shared equally between the transistors. The value isn't critical, I chose 0.1R because I originally designed it for high currents, for 5A you can use 1R which will be easier to get hold of.
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #10 on: June 06, 2010, 01:44:02 AM »
if i change the value of 1R instead of 0.1R than what change in circuit current
the resistor wattage
the voltage across R = ?
the current across R = ?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #11 on: June 06, 2010, 02:54:23 AM »
Changing the value will not change the current, the circuit does not provide current regulation, it's just that if the voltage drop across the resistors is very low, the current sharing won't be very good.
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #12 on: June 06, 2010, 04:50:54 AM »
Quote
please explain it using examples
if 10R resistor use than
Logged
Fight
Newbie
View Profile Email
« Reply #13 on: June 06, 2010, 04:57:42 AM »
what is the efficiency of these circuit
if this method using with lm317 and lm338 than thses ic better current and voltage or not
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
