Home Community
LM338 Power Suply Current Regulator
May 25, 2013, 09:21:54 AM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| |-+  Datasheet/Parts requests (Moderators: hotwaterwizard, Herman the German)
| | |-+  LM338 Power Suply Current Regulator
« previous next »
Pages: 1 2 [3] 4 5 6 Print
Author Topic: LM338 Power Suply Current Regulator  (Read 10329 times)
Fight
Newbie
View Profile Email
« Reply #28 on: June 13, 2010, 06:09:08 AM »
Quote
Quote
1.  This circuit provide good current limiting and
2.  5A current provide at all voltage range 1.2 to 30V  and
3.  good voltage regulation from 1.2 to 30V
Quote
Those aren't questions, they're statements.
These statements ok or not
Quote
Here's a link to a PSU designed for 0 to 13.8V. The same method could be used with the LM338 and current booster to get 0 to 30V. If the link doesn't work I'll post an attachement.
http://www.silicontronics.com/index.php?action=ezportal;sa=page;p=19
this link is not open please attatch
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #29 on: June 13, 2010, 09:12:10 AM »
What browser are you using?
It should work on all browsers.
Where do you live?
Some governments block content they don't like and although Silicon Tronics doesn't contain any political or pornographic material, it might be hosted on a server which does and could be blocked in China and other countries with strict Internet filtering.
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #30 on: June 13, 2010, 11:33:24 AM »
Quote
Internet explorer
Quote
Where do you live?
Pakistan
about 2 or 3 days this site doenot open
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #31 on: June 13, 2010, 01:31:48 PM »
What version of Internet Explorer do you use?
It works for me in IE 8.
There is some Internet censorship in Pakistan but it's not as bad as some countries.
http://en.wikipedia.org/wiki/Internet_censorship_in_Pakistan
The statements you made a couple of posts ago are true.
I've attached the circuit I was talking about.
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #32 on: June 14, 2010, 07:01:07 AM »
Very Very thanks a lot Hero
Only using Lm338 except lm317
please explain this circuit how circuit work
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #33 on: June 14, 2010, 11:19:56 AM »
I explained how the regulator works on Silicon Tronics which you can't access so I've coppied and pasted the text.
The circuit compriese of two parts: the rectifer/voltage doubler and the actual regulator iteslf.
Rectifier
This part of the circuit converts the 15VAC from the transformer to +20V and -9VDC.
The -9V rail it derived from connecting a negative voltage doubler (formed by D2, D3, C2 and C3) to the AC side of the rectifier an its output is restricted to 9V (see R1 and D4) because the op-amp is only rated for +/22V. R1 and D4 can be substituted for a negative regulator (LM78L09 or LM79L12) if you like.
Regulator
This part of the circuit is actually responsible for converting 20VDC to the lower output voltage.
U2 forms a differential amplifier which looks at the voltage across R7; this should be a constant 1.2V to 1.3V depending on the LM317. The negative input of the differential amplifier is at the positive side and the and the positive input is at the negative side of R7 which causes U2's output to sit at -1.2V to -1.3V.
The 'usual' negative point is connected to U2's output, therefore subtracting it from the output voltage meaning the output can go all the way to 0V.
Now we might have a problem: we should only expect the 741's output to be able to supply a maximum of 10mA. The trouble is the current flowing through R6 can be as high as 13mA. The chances are it'll be all right since the datasheet of the 741 says it might be able to take 20mA but the minimum ia 10mA.
Just in case the op-amp might not be able to handle 13mA I've connected a 1k pull-down resistor (R8) from U2's output to -9V, which will take 7.75mA away from the output so it only has to supply 5.25mA.
NOTES:
If you don't have the
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #34 on: June 15, 2010, 06:57:07 AM »
Very Very Thanks a lot
Question about Diagram which send ago
IC1(Which use for current regulator)
V = 3V    &    I = 5A    &    P = 15W
IC1 handle 15W power
IC2(Which use for Voltage regulator)
V = 30V    &    I = Depending upon BE resistor let 50mA    &    P = 1.5W
IC2 handle 1.5W power
Transistor(Which use for Current booster)
V = 30V    &    I = 5A    &    P = 150W
Transistors handle 150W power
am i reight or not
How the design heat sink from these ICs and transistors (Size Shape Material and other)
Thanks
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #35 on: June 15, 2010, 08:53:00 AM »
The voltage regulator and current regulator will have 30V or more across them sometimes. An LM338 limits its current when it has more than 10V from its input to its output. Then its max current is only 1A.
With a voltage of 30V and a current of 1A then it dissipates 30W, not 3W.
A "150W" power transistor can dissipate 150W only if its case is cooled to 25 degrees C with liquid nitrogen. If it has a huge heatsink and a fan then it can dissipate only 75W when it will be at its absolute max allowed temperature.
EDIT: Fixed a typo.
Logged
Fight
Newbie
View Profile Email
« Reply #36 on: June 16, 2010, 06:32:12 AM »
Quote
if lm338 use as current regulator and input voltage 40V
the voltage drop across ic at 5A equal to approxomately 3V
and at this condition lm338 can handle 5A
than P=3*5 = 15W
am i right or not
than next
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #37 on: June 16, 2010, 06:53:41 AM »
Quote
than P=3*5 = 15W
am i right or not
Yes but then its output voltage must never be less than 37V.
If you connect a load that tries to draw more than 5A then the current regulation will reduce the output voltage until the current is 1A. Then the LM338 current regulator will dissipate as much as 40W!
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #38 on: June 16, 2010, 07:54:20 AM »
Fight,
The circuit I posted in my first reply to this thread uses several power transistors so the power dissipated by each power transistor is only around 35W.
http://www.electronics-lab.com/forum/index.php?topic=20224.msg92354#msg92354
We're going round in circles.
Logged
I also post at:
Fight
Newbie
View Profile Email
« Reply #39 on: June 17, 2010, 06:44:30 AM »
Quote
Hello audioguru
if max draw 5A current than
max Power dissipation of IC 3V*5A =15W
if lm338 use as voltage regulator with transister use as current booster attatch diagram than
max power dissipation
am i right or not
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #40 on: June 17, 2010, 08:25:19 AM »
If you set the current regulator to 5A and load the power supply with less than 5A then the current regulator is saturated and does not get hot.
But if you have a load that tries to draw more than 5A (maybe the output is accidently shorted) then the current regulator will have its max current (which might drop to only 1A) and it will have the max voltage across it (maybe 36V) and it will be extremely hot.
Your voltage regulator with the four current-boosting transistors has the base-emitter voltage of the transistors (maybe 0.8V) plus the voltage across the 0.1 ohm resistors (0.125V) for a total of 0.925V. The 4.7 ohm resistor with a voltage across it of 0.925V has a current of 197mA which is also the current of the regulator. If the input voltage is 36V, the output voltage is 5V and the current is 5A then the regulator didssipates 6.1W and the transistors each dissipate 37.2W.
Logged
Fight
Newbie
View Profile Email
« Reply #41 on: June 18, 2010, 11:46:19 AM »
Quote
Quote
This situation the heat sink size
Quote
Ok
This situation the heat sink size and how design size of heat sink
Quote
how the regulator didssipates 6.1W
V = 5V  and I = 197mA     then P = 0.985W   = ?
and how the transistors each dissipate 37.2W
V = ?  and I = 5A    then  p = ?
please explain
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
