Home Community
Simple issue: Solar power charger and inverter concurrently on battery
Welcome, Guest. Please login or register.
May 23, 2013, 10:45:48 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  Simple issue: Solar power charger and inverter concurrently on battery
« previous next »
Pages: [1] Print
Author Topic: Simple issue: Solar power charger and inverter concurrently on battery  (Read 552 times)
Guldborg
Newbie
View Profile Email
« on: July 13, 2010, 05:35:13 PM »
Hi electric people, I have a couple of questions, that you maybe able to help with:
I have a garage without power and have therefore made a setup with a 60 Ah car battery, a 300 W 12V-220V inverter with power outlet for a lamp and want to add a 18 Watt solar power charging-array.
1) Can I connect the solar power charger (incl. regulator) and the inverter to the battery at the same time without hazards?
From invertere manual: "Disconnect AC inverter before using a battery charger (...) Failure to disconnect the inverter prior to connecting af charger may result in an input spike which will damage the inverter. CONNECTING THE INVERTER'S INPUT TO A BATTERY CHARGER WILL VOID WARRENTY AND MAY DAMAGE INVERTER".
Can 'input spike' also occur when connecting a continuesly charger as the 18 solar power charger? Please note, the charger has a regulator. Is it likely for the inverter to be toasted, if I connect both units simultaniously - and as you see charge an discharge at the same time?
The idea is to have this setup on all the time, so the battery will be charged slow, nice and easy after any use (discharging). Is it possible?
2) My inverter is always ON, because the lamp is movement sensitive. The battery has already been drained after a couple of weeks (haven't bought solar power charger yet). The inverter lights a small green diode when ON.
How much kWh does it 'cost' to have the inverter on standby? How can I measure? Shall I look for a specific spec in the manual?
Hope for help.
Best regards,
Jens Guldborg
Odense, Denmark
NB: Danish links!
Inverter: http://www.harald-nyborg.dk/merinfo.asp?varenr=6656&Grp=&n=10
Solar power charger: http://www.batteribyen.dk/18w_solar_panel_kit_inkl__laderegulator-p-4676.html?cPath=521_529&osCsid=7a278925bbfafbef25698f2915f12d92
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
