Home Community
Rpm rev counter to high
Welcome, Guest. Please login or register.
May 24, 2013, 03:23:39 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronics chit chat (Moderators: redwire, wise old man)
| | |-+  Rpm rev counter to high
« previous next »
Pages: [1] Print
Author Topic: Rpm rev counter to high  (Read 525 times)
Whittock1
Newbie
View Profile Email
« on: September 04, 2010, 08:43:40 AM »
Hi I was wondering if you can help I have a rpm counter for my car it's reading to high is there a way of wiring a componet in line from the coil to the counter to reduce the time down to match the counter. On the back off the counter there is a switch to adjust the led display 4 6 8 these donate how many cylinders you have on your car, select the amount of cylinders ie 6 then set the switch to correspond to that. My problem is I have a 12 cylinder and the settings only go to 8 max. If I set it to 4 it reads 5000 rpm (when at idle 1000) when set to 6 it reads 4000 and when set to 8 it reads 3000. Can it be done ? I'm guessing if it had more settings ie 10 or 12 it would just keep coming down till the readings were correct. Cheers . I forgot to mention the pick up is from an alternator it puts out a 12 v signal which is switching the faster the alternator spins ie revving the quicker the signal becomes.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: September 04, 2010, 10:30:25 AM »
It's possible that passing the signal through a divide by two counter and setting the numbver of cylinders to 12 will work.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
Whittock1
Newbie
View Profile Email
« Reply #2 on: September 04, 2010, 01:49:58 PM »
Hi sounds good  Smiley but in laymans terms how do we do it ?  Huh Remember the rev counter only goes up to 8 . Thankscforvhelping
Logged
Whittock1
Newbie
View Profile Email
« Reply #3 on: September 07, 2010, 03:53:52 PM »
 Huh
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
