Home Community
LM317 Pspice
Welcome, Guest. Please login or register.
May 22, 2013, 11:58:22 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronics chit chat (Moderators: redwire, wise old man)
| | |-+  LM317 Pspice
« previous next »
Pages: [1] Print
Author Topic: LM317 Pspice  (Read 1356 times)
krispots
Newbie
View Profile Email
« on: June 06, 2010, 02:55:35 AM »
ok, so i'm trying to simulate this circuit. i'm using transient analysis on this one and then when i clicked run, the green circle above the Lm317 appeared. Is there a problem in this circuit? or this anything first i must do before i can use the LM317 here? the voltage readings indicate that there is a problem and i don't know what it is. Anyone can help me?
I'm using Orcad Capture 9.2
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: June 06, 2010, 03:06:56 AM »
You haven't said what software you're using so how are we supposed to know what the green circle means?
There are two things wrong with the circuit: R1 should be 120R or less for the LM317 and the output voltage is set for more than 28V so it will be in drop out; maybe the green circle signifies the latter?
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
krispots
Newbie
View Profile Email
« Reply #2 on: June 06, 2010, 03:16:18 AM »
oh, sorry about that, i'm using orcad capture 9.2.
i'm trying to simulate a typical application based on the circuit described in a national semiconductor datasheet for the Lm317
here's the link
http://www.futurlec.com/Linear/LM317HVT.shtml
i'm new to using orcad, i thought maybe you need to tweak something on the LM317 parameters which i currently don't have any idea of.
thanks for the reply
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: June 06, 2010, 03:30:25 AM »
I've never used Orcad so I can't help you with that.
The only thin I can suggest is addressing the concerns I raised in my previous post then trying again.
Logged
I also post at:
krispots
Newbie
View Profile Email
« Reply #4 on: June 06, 2010, 03:38:19 AM »
i tried reducing R1 to 120 ohms, still the problem exists.
i found out now that the green circle signifies a lack of pspice template for the LM317, and maybe the program thought of it as an open circuit.
thanks for the reply.
still, if anyone can help me or anyone can post a link to a tutorial using orcad, that would be much appreciated.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #5 on: June 06, 2010, 03:45:15 AM »
What output voltage do you need?
The circuit is no good if the values are wrong.
Logged
I also post at:
krispots
Newbie
View Profile Email
« Reply #6 on: June 06, 2010, 03:50:47 AM »
i'm experimenting with the simulation software to match the actual LM317 and the part in orcad, so that i can just simulate in the future if i need some output voltage. Unfortunately, i don't know yet how to use the program.  Smiley
Logged
ardian
Newbie
Gender: Female
PCB Design
View Profile WWW
« Reply #7 on: November 15, 2010, 07:13:43 PM »
Although LM317 is an adjustable regulator, it is sometimes preferred for high-precision fixed voltage applications instead of the similar LM78xx devices because the LM317 is designed with superior output tolerances
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
