Home Community
Making Connections
May 25, 2013, 08:49:33 PM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  Making Connections
« previous next »
Pages: [1] Print
Author Topic: Making Connections  (Read 1482 times)
Silent Jack
Jr. Member
View Profile
« on: February 23, 2011, 03:05:21 PM »
Looking at hooking up some high voltage capacitors in a series parallel configuration and was hoping some of the experienced folks here could share their recommendations for how best to connect them.  I've had traces posited, as well as solid-core wires and bus bars.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: February 24, 2011, 01:55:41 PM »
You really need to provide more information.
It depends on the capacitance, voltage and rate of discharge.
Logged
I also post at:
http://www.silicontronics.com
Silent Jack
Jr. Member
View Profile
« Reply #2 on: February 24, 2011, 02:01:24 PM »
Happy to; 6x 400V capacitors @ 470uF.  Arranged 2x wide, by 3x deep.  As rapid a discharge as possible once fully charged (Dumps to a solenoid).
Logged
KevinIV
Electronics God
Gender: Male
View Profile
« Reply #3 on: February 24, 2011, 02:13:56 PM »
Solid copper wire solders good to component leads. High voltage on PCB's isn't good. Any sort of damage has to be evaulated for reuse.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #4 on: February 25, 2011, 04:38:47 PM »
Just make the connections as short and as thick as possible.
What are you using for back-EMF protection? Electrolytic capacitors don't like being charged in the reverse direction.
Logged
I also post at:
Silent Jack
Jr. Member
View Profile
« Reply #5 on: February 28, 2011, 01:06:32 PM »
What have you found to work best in your experience?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #6 on: February 28, 2011, 01:45:00 PM »
I've never done it before so wouldn't be able to answer that question.
What's the resistance and inductance of the coil? You should ensure the impedance of the capacitors and wiring is significantly less than that of the coil.
Logged
I also post at:
Silent Jack
Jr. Member
View Profile
« Reply #7 on: February 28, 2011, 03:12:58 PM »
I could give you the physical specs of the coil, but I don't know its impedence.  What is the best way to determine it?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #8 on: February 28, 2011, 03:58:08 PM »
By using a formula which can be found using Google.
http://www.google.co.uk/search?hl=en&client=opera&hs=4eV&rls=en&channel=suggest&q=inductance+calculation&aq=f&aqi=g7g-m3&aql=&oq=
Logged
I also post at:
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
